Hi, guys help needed I recently bought Sony KD-65AG9 but still waiting for it to be delivered. I made up a wall panel using studs and cls timber across as a finish up. Does anyone know or have reference measurements from top, bottom, left side and right side for the four holes at the back of the tv where the bracket is to be attached. I need to affix the bracket in position before the tv is delivered, thanks in advance.
reference image attached below:
In the attached document you may find all the technical information for your new tv, enjoy it!
Hi, thank you very with such helpful specs data exactly what I’ve been looking for you such a life saver much appreciated.
Thanks once again…😉😊
