KD65A1 Problem
SOLVED
BENZ505
KD65A1 Problem
My KD65A1 is just 4 months old, recently it has been TURNING ON randomly...please help
1 ACCEPTED SOLUTION
Accepted Solutions
cass_n
You could also try disabling Remote Start in the menu and see if this works?
6 REPLIES 6
cass_n
Hi @BENZ505 and welcome to the community,
Can you please try the following to see if this solves the issue?
  • Check if [On timer] is activated.
  • Disable the [Auto TV on] setting in [BRAVIA Sync settings].
(Found in the Help Guide here)
Cheers,
C
BENZ505
Did your suggestion but unfortunately, it turned on again after just over an hour...please advise.
cass_n
BENZ505
Thanks, so far no similar problem occurred the past 24 hours...
cass_n
Glad to hear it!
BENZ505
Just got home from work, been away from 8 this morning, the tv was on again, for how long??? I can’t tell but the tv screen is warm to touch...and I thought the problem has been solved...any advise would be highly appreciated
