Sony KDL-43W755C Android TV --- BBC iPlayer disappeared
simonoleary
Hello,
I got this TV last Saturday and on that day we spent a good few hours using iPlayer which had a tile on the Home Screen.
On Sunday however, that tile had disappeared.
What's more, I can't even see BBC iPlayer in the Google Play Apps area.
What's happened?
How do I get BBC iPlayer Back?!
Thanks
Simon
2 REPLIES 2
babines
Had this happen today on a KD-49X8305C which I have had for just one week.
P.S. Why don't they put the dates on postings?
Anonymous
Not applicable
Hi there
A couple of thing:
  1. iPlayer is dependent on a UK based ip address.  Ensure that it is by going to http://ip-lookup.net
  2. If you have enabled 'restricted profile' mode, iplayer disappears.
  3. If you're not in the UK, but using a UK based VPN, then the BBC are blocking it:
http://www.theregister.co.uk/2015/10/19/bbc_cuts_off_vpn_to_iplayer/
Cheers
PS: You used to be able to enable proper dates on postings in your settings, but for some reason this setting is no longer available.  I have dates enabled, but cant switch them off now, if i wanted to that is
