Camera problem on different build
hellohelloworld
Let me summerise the  camera problem on different build:
19.2.A.0.391:
front camera: very good
rear camera: refocus when taking video and photo
solution: I've tried around 6 to 7 camera apps, only cinema fv-5 works fine on taking video without refocus, but only landscape mode, you need to use video rotate app after taking vertical video.
19.2.A.0.72:
rear camera: flash light not work properly, refocus when taking video and photo, dim photo
soultion: turn on the torch mode, use cinema fv-5 for video taking
19.3.A.0.470:
front camera: poor, dim photo, flash light not work properly
solution: turn on HDR is better, but the image is too bright, not quite natural
remark:  1. turn on the torch mode still not work
                2. tried different camera apps including camera fv-5 still not work,
solution:  "a better camer" and "camera fv-5" on lollipop, both work fine on front cam 4:3 including the flash light.
solution: Cameringo lite can take clear pics for all resolutions at low light or bright light condition. However, no real flash light support.
                 HD camera pro work perfect for 4:3. The flash light also works properly. However, no hardware button support.
rear camera: I have not tested it seriously, but the flash light problem fixed
rear camera: good
Correct me if I am wrong!
Thanks!
7 REPLIES 7
gius321
those different builds were all official updates from update center?
hellohelloworld
yes, official C3 dual rom from xperifirm, hongkong kitkat rom, india lollipop rom
Uliwooly
@hellohelloworld
Perhaps other C3 users are willing to test this.
hellohelloworld
thanks ravi_p7's  information from other post,
I have just updated the test result.
ravi_p7
U r welcome.
hellohelloworld
  1. Try cameringo lite, clear pic for all resolutions.
hellohelloworld
Try HD camera pro, work for front cam 4:3 including flash light.
