Even when the battery condition was full, it will suddenly shutdown and come back in 1%(when restart phone on charging will go back to the previous battery %). I tried to run in safe mode, force shutdown, and system repair + factory reset but isn't fixing the issue. It was battery malfunctioning? But in fact the phone was all normal if I didn't run any application at the moment, or using application on charging. Any solution for my problem ?
I see that you already have tried most possible ways to diagnose the phone, the last resort would be to have your phone checked at your local service center for hardware problems Local support
