how to block calls
Carly09
how to block calls
Its so inconvenient that i cannot block calls... Theres been multiple numbers that has been calling me and i dont know who they are. Please help
4 REPLIES 4
profile.country.US.title
Qatrium
Hello @Carly09 and welcome to the community!
In your Phone app, long tap on the entry you want to block, and a menu will appear. You should find the option to block there.
Carly09
Phone app? Where can i find that?? Pls need answers
Qatrium
@Carly09
It's the app you use to dial calls and to access our call log.
Jonas
Master
Hi @Carly09, welcome to our forum!
There is no feature in your phone that will block calls from a specific number, to do that you will need to download a third party application from the Google Play store. The way @Quester mentioned is only available in Android 7.0.
You can however send all calls from a specific number directly to your voicemail. By doing this you will not receive the call to your phone and you won't get noticed that you have a missed call (unless your operator sends out an SMS when you have a new voicemail). To do this, open up the contacts application in your phone and add the number you want to send to your voicemail and before you tap "Save" tap the 3 dots in the top right corner and check the box next to "All calls to voicemail" and then save the contact.
I hope that helps! Slightly_smiling_Face
