bought a hdr-cx130e from Argos in Jan, i have all of the details and registered the camera on My Sony which includes the serial number & date of purchase, but I cant find the original Argos receipt, will I have a problem getting a repair under warranty ? I presume its pointless trying to get a copy receipt from Argos ?
Basically the shutter that springs shut when opening & closing the viewfinder isnt working and its now shut half way, can hear it trying to open/close but failing, maybe theres a spring in there thats broken, either way its only 6 months old and not used that much but stopped working when i needed it most. is this a common problem ?
Gelöst! Gehe zu Lösung.
Hello threeputt - Welcome to the Sony Forums
If you do not have your original receipt, it was probably a smart move to register the camera online with Sony at the time of purchase as this will help. I would advise you to contact customer services to find out about getting your camera repaired and there are full contact details in this thread:
http://www.sony.co.uk/discussions/message/651957#651957
If you explain that you do not have your original receipt, hopefully they will still be able to help you. I wouldn't bank on being able to get a copy of your receipt from Argos but if you purchased it using a credit or debit card it may be possible to locate the transaction on an old statement - hopefully it won't come to that
Thanks,
Simon
Thanks,
Simon
