I have a Sony DSC-H3, which we have a problem, no longer the flash fire automatically. If you manually lift works perfectly! The camera has been reset but the problem is not resolved! Thanks to those who will respond! Have a good day!
Hi adryanam, welcome to the Sony Forums
Your camera is in Auto Flash mode when there is no visible flash symbol in the top right corner of the display. If you see a flash symbol, one of the various manual flash modes is engaged.
If your camera is set to 'Auto' (the green camera symbol on the Mode dial) and you're sure all other controls are at default settings, and the flash still won't work in auto mode (no visible flash symbol on the display) then it's possibly time to contact Sony Support.
They run through some solutions with you and advise you about a possible repair, should that be necessary. The support link to follow for your camera is below:
http://support.sony-europe.com/dime/digistill/cyber/cyber.aspx?site=odw_en_GB&m=DSC-H3
Cheers
Mick
