SONY DSC HX400v Power Supply
OPGELOST
TPatel786
Ontdekker
Hi all,
I have just purchased a Sony DSC HX400v after having used a HX300. I used to charge the HX300 and use it to take vides at the same time, however, i cant seem to do the same with the HX400v.
Is there a special adapter to use? if so can anyone help me with where to buy it?
Thanks in advance :slight_smile:
1 GEACCEPTEERDE OPLOSSING
Geaccepteerde oplossingen
Nobody-in-particular
Bijdrager
Hello and welcome.
On checking the user guide it would appear that using either the AC-UD10 or AC-UD11 Adaptor could allow you to shoot or review photos when connected to AC power.
Bekijk de oplossing in de community in het oorspronkelijke bericht
4 ANTWOORDEN 4
Bijdrager
Hello and welcome.
TPatel786
Ontdekker
Thank you for the quick response! Will have to order one now :slight_smile:
Bijdrager
You are most welcome TPatel786.
macman2905
Nieuw
I often carry a portable USB Power supply and keep the USB cable plugged into the charging port, whilst taking photos and video. Works well if you don't get tanged up in the cables!
