danens
New
HT-XT3 Spotify issue
Hi!
It seems like I'm not able to connect to Spotify since the last update was made. It changes the input on the HT-XT3 to Spotify but no audio is coming from the speakers. On the PC I can't even select the HT-XT3 speaker as output device which was possible in previous versions.
1 ACCEPTED SOLUTION
Accepted Solutions
danens
New
I did a factory reset and after that I was prompted to upgrade the firmware.
After the upgrade the name of unit was really strange. See picture below.
undefined
I tried to change the name two times without success. One time the unit froze when I pressed OK to save the new name (tv).
I restarted the unit and tried to access Setup menu, but it said "Initialising, please try again" for ~30 mins so I removed the power plug and did a new reboot. When it started again I was able to access the Setup menu. I did a new factory reset, but only for System settings. After that reset the name was reset to the name it had when I first started the unit. Spotify seems to work now. So... problem solved, piece of cake!
3 REPLIES 3
Anonymous
Not applicable
Hi there
Suggest a factory reset firstly to be honest. The option to reset should be in the settings of the soundbase.  Give that a go - a long shot I know.
Cheers
danens
New
undefined
Anonymous
Not applicable
Phew - a long way round, but it seems the HT-XT3 eventually got there in the end.  I bet you're relieved :slight_smile:
Thanks for the update.
