Hello.
My setup is TV 55XE9005 and soundbar HT-ST5000 (connected with HDMI ARC). Both with latest updates.
Everything is working well but when I connect my set-top box (cable) to the soundbar via HDMI (HDMI 1), I face this problem:
The soundbar always changes the input from "TV" to the HDMI 1 where my set-top box is connected. If I change it back to "TV" the soundbar switches it back to HDMI 1 after I turn the soundbar off and on again.
Is there a way to keep the "TV" selection always on?
Hi Andy,
We'll look into this further and update you when possible. Meanwhile, some other members may have some tips to share.
Best wishes,
Ed
Hi andybandy222,
Welcome to our community!
I'd like to suggest a slightly different connection map. Since you're already using HDMI ARC for connection, could you try to connect the set-top box into the TV instead of connecting it to the sound bar?
Let us know if this resolves the issue.
Regards,
Batee5
