WiFi Direct in xperia M
GELÖST
saurabh_gohil
Besucher
Hello,
          Can anyone please help me to use wifi direct in my Sony xperia M,there is no option to send files using wifi direct as well as no option to send using NFC.Share option does not contain NFC and WiFi direct it shows Bluetooth and other options except NFC and wifi direct.
Any help is appreciated.
thanks in advance
23 ANTWORTEN 23
Basant
Besucher
yeah after searching when it finds a device u connect n transfer.. see that the opposite device is switched on , supports wfi direct/nfc and has it enabled.
saurabh_gohil
Besucher
Okay,i'll try that once again and let you know
Basant
Besucher
in case your problem is solved Saurabh then plz mark the thread as solved.
saurabh_gohil
Besucher
yes sure i wil do that as soon as i check it,i was litle busy so will mark solved ASAP.
saurabh_gohil
Besucher
I tried and both devices shows connected but now if click on connected devices it only shows option to disconnect,
there is niot actual option to send media/files using wifi direct.
any help is appreciated...
saurabh_gohil
Besucher
Sony support center's reply to the issue.
Turning on Wi-Fi Direct
Android 4.1 / 4.2
To turn on Wi-Fi Direct
  1. From your Home screen, tap the Application screen icon.
  2. Find and tap Settings > Wi-Fi.
  3. Press the menu key > Wi-Fi Direct
  4. Make sure Wi-Fi Direct is turned on in the other device.
  5. Tap Search for devices.
  6. Under PEER DEVICES, tap the device you want to connect to.
  7. Wait for the status under the device name to change from Invited to Connected.
Sending files using Wi-Fi Direct
The advantage with sending files with Wi-Fi Direct is that it goes quicker to
send larger files than with, for example, Bluetooth.
To be able to transfer files between two devices you have to:
  • Make sure both devices are Wi-Fi Direct compatible
  • Make sure that both devices have installed Office Suite Viewer 7 or later
  • Share the files using the Office Suite Wi-Fi Direct menu in, for example, Album if you send a photo
Downloading Office Suite
To download Office Suite
  • In your Xperia™ device, download and install Office Suite Viewer 7 or later from Google Play.
Sharing a photo using Wi-Fi direct
To share a photo using Wi-Fi Direct
  1. Open Album, tap the photo that you want to share with another device.
  2. Tap the share icon and select OfficeSuite Wi-Fi Direct. Alternatively, tap the OfficeSuite Wi-Fi Direct icon.
    OfficeSuite Wi-Fi Direct starts scanning for Wi-Fi Direct devices automatically.
  3. Make sure the device you want to share the photo with has opened Office Suite.
  4. Under Available devices, tap the device you want to share the photo with.
    Its status changes to Invited.
  5. Wait for the status to change to Connected. This may take some time.
    The photo is now sent to the other device.
Basant
Besucher
its really simple actually is nt it??? Slightly_smiling_Face Slightly_smiling_Face Slightly_smiling_Face
ak98
Besucher
use office suite application provided by sony in the phone to share with wifi direct.
partsguy
Besucher
I am trying to connect my tablet z with my experia m. Both are fully up to date, both have officesuit 7. They are " connected" to each other on the setup screen. When I try to send a file from within officesuit m to z, office suit cannot find the other device (tablet) or sometimes says that File Commander has stopped. Anyone got any ideas, I would have thought going Sony to Sony would have been easy. Been at it for quite a while without sucess.
BharathBK_1983
Besucher
Please tell me how to release lock symbol while using wifi direct
