xperia p low call volume
SOLVED
Peter_Schicker
I upgraded a week ago to an Xperia P, but find the in call volume very low. The volume is set to maximum and I can´t do anything against this problem. So I do have a new smartphone for 150€ but it is not able to do simple calls ...
1 ACCEPTED SOLUTION
Accepted Solutions
Samuel1
Hero
I might have misunderstood you here - you didn't update your phone software, right? You updated to a Xperia P from some other phone?
If that's the case, I'd recommend that you return to the store to compare the Xperia P to another unit of the same model to see if the volume is the same. If it's not, they might be able to replace it for you.
4 REPLIES 4
Samuel1
Hero
So what you're saying is that the call volume were lowered after the update? Is that correct? If that's the case, it seems like something has gone wrong, as it shouldn't be changed by any update. Try to reset your phone and see if the problem still persist.
What are your thoughts about this forum? Let us know by doing this short survey.
Peter_Schicker
Yes that was what I wanted to say. I´ll tried to rest the phone for two times, but nothing changed.
Samuel1
Hero
Peter_Schicker
I made a system update and after that update the call volume was lowered. I donot understand why thi happened. After not finding any solution I decided to reset my sony xperia p. But I still can´t hear the person on the other side of the line well. I have to put the loudspeaker on to be able to hear them well.
The funny thing is before I made this update everything was fine.
