How do I get my Sony DW-520A to write to DVD at More than 2X speed it says it can write at 8X but when I put a 8X DVD-R in it will only write at 2X speed?
Please help I have searched the forum with no results.
What software are you using to burn your DVD's?
What is your Vaio model?
Make sure you're burning with the AC Power plugged in and using the full AC power setting.
The software is nero 7 but the same with roxio that came with the vaio. model no VGN-FE21M and my laptop is always pluged in and fully charged. By the way also running vista but it was the same on XP.
Do you know what firmware version your drive has?
This information can be found through Nero but i can't for the life of me remember how!
Could it just be the media that I am using?
Could be, is it rated for 8x?
I prefer Memorex, Sony and Verbatim, better quality disks last longer, I got some cheap disks 10 years ago and they have now corroded
They are Mr DVD from asda rated at 8X will buy some sony and try them.
Hi ianmolyneux,
I have found TDK DVD +R discs to be very reliable, I have problems in the past burning to cheaper DVD's
Hopefully you will have more success with the new Sony DVD's..
