please help: my laptop is very loud
robotslover
Dear All,
I have sony vaio PCG-FR315M laptop. It has very loud noise and dont know what to do about it. please help.
thanks in advance
14 REPLIES 14
rich912
Contributor
Hi and welcome to the forum.
How old is the notebook? If this has developed recently it may be that the cooling vents need a clean.
I suggest that you download MobileMeter and check the CPU temperature.
Go n-éirí an bóthar leat
Thalamus.
Champion
Rich912,
The English hyperlink does not seem to work on the mobilemter page, so I have posted an alternative link
Hope you don't mind :slight_smile:
rich912
Contributor
Thanks for that Thalamus, no it is not working at this end either.:smileyconfused:
You can of course just click the download link in the Japanese page but your link is certainly clearer. Thanks:smileyhappy:
robotslover
Dear All,
Thanks a lot for the quick replies. I thought about the cleaning thing and tried to open the laptop, but did not manage to even after removing all screws. Is there any hint for unassembling it?
I searched on the net for a long time and found instrutions for many models but not for the PCG-FR315M model.
Also, is there a fan driver from sony, or an upgrade for the BIOS that can help?
i just downloaded the mobilemeter and found that the temperature of the CPU is 51.
thanks a lot
rich912
Contributor
This is a guide for the FR215H, as posted by another member, but your model will be very similar. Click on the English link at the top of the page.
carthorian
Dear All,
thanks a lot
51 is quite high for a notebook in my opinion. Mine is at least 10° less. Be glad your fan still works properly (though load), otherwise you might experience other problems.
Thalamus.
Champion
Mine seems to runs smoothly & happily at 48 to 51:smileyconfused:
rich912
Contributor
It very much depends on the type of CPU in the notebook. Most have Mobile processors which are designed to function at higher temperatures than the desktop processors that are also used in notebooks.
My notebook has a Mobile Intel Pentium Processor that runs quite happily between 54 and 56 deg but this would be far too high for models using a desktop processor.
profile.country.en_GB.title
kee-lo_
I get the same sort of temps as Rich
