Can I pick your brains please :smileygrin:
I've had two power supplies fail on my desktop within 6 months. Getting a little pissed off now, so any general reasons that I could investigate would be cool.
Cheers guys
Hi Faith,
Overheating comes to mind…
Do you clean the fans and cooling vents on a regular basis? Silly question really :smileygrin:
Hi Faith,Thanks for your reply Rich,
Hi Faith,
Is your PC plugged into a anti-surge device..?
It could possibly be a faulty/damaged circuits on the motherboard..!!
Have you changed or added anything new inside your system..?
Thanks for your reply Thalamus,
No I haven't got an anti-surge device, I don't have a problem with my laptop, which is on the same plug - not sure if that would mean it's not a problem
I didn't think it was a fault with the motherboard, as last time it happened, on replacing the power supply it was all fine again.
Haven't added anything new to the inside since I last replaced the power supply.
Sorry guys, it's all a bit vague.
No I'm not that technical lol, nothing new before the original PSU failed, and I replaced with an identical 450w PSU
Another thing that has just occurred to me is the fact that the desktop is always physically plugged into the mains, so even when the desktop is switch off the mains isn't. So could this affect the life span of the PSU?
you wouldn't believe how much crap gets clogged up in it
hahahaha, not me matey, would never smoke in the houseyou wouldn't believe how much crap gets clogged up in it
I would!! And the ciggies have a lot to do with it... :smileygrin:
