Problems with setup...
Mumbler82
I'm really in need of some help getting through the initial setup. The screen on my vaio pocket has been broken for a while but I've been quite happy just using the remote. A few days ago however I reset it, not realising i'd have to set it up again, and since the only way to get it setup is by using the g-sense pad and LCD screen I'm now stuck without a player.
If anyone could possibly guide me through which buttons to press to get it setup I would be very greatful. The only thing that needs to be right is the language (english), after that I just need to confirm it so that it'll start working again.
Again any help would be much appreciated... cheers
4 REPLIES 4
CAM
Try this link and download the Operating Instructions required. http://www.vaio-link.com/manuals/manuals.asp?l=en&m=1745
hope it helps
CAM
Mumbler82
Thanks for the help but I've already read through both manuals, the problem is that I don't know which button selects which language etc as i can't see the screen, and don't know where the ok button is.
The only settings needed for the initial setup are:
1) Language
2) Sensitivity
3) Clock
and then i need to go to OK
What I need are either screen shots (of each screen), or for someone who actually knows which g-sense buttons to press to tell me exactly which buttons i need to get it setup. Sensitivity and clock aren't important as I can't see the LCD but I need it to be in english, as i suspect this will also affect the remote.
Again any help is appreciated
BLINX32
I'll post one when I get home this afternoon, it will not have screen shots but I will tell you which button of the 25 to press at which time, I hope this will help you. :smileygrin:
Mumbler82
Yeah if you could do that it'd be wicked cheers. Wouldv'e replied earlier but i've been away...
