Hi, i have got the sony ar11m just over a week ago and I have found the tv tuner is not working as it should. In media centre when I go to settings and then click on tv, after a while an error message comes up saying 'the tv tuner is malfunctioning or not installed'. I have tried uninstalling and re-installing the drivers to no avail. in device manager it says 'the device is working properly'. has anybody had this problem and if so have you been able to correct it. Also i suspect that this is causing media centre to freeze because when i point to my tv or settings in media centre it freezes for like 15 seconds before continuing as normal. I have tried to access these options from other laptops and the media centre responds instantly. Please can you advise me on these issues and thanks in advance!
