I have installed SP2 and by the end of setup, a message came telling that was a problem installing bleutooth, and that could not be working properly because of that.
I went to Device Manager and Bluetooth is not there.
I went to vaio-link support and there says for we look in C:drivers and the setup is there, but i do not have drivers in there for bluetooth, so..what can i do to solve the problem...?
Just for info, wheni start the Vaio the bluetooth light lights up, but then goes down.
Another problem is with the volume controls that the unit have, after the install they stop working, the service pack been installed via Windows Update, and in these i didn't ahd any error message.
Thanks for you help in this
Best Regards
fercruz1:smileysad:
Hi fercruz1,
The original Bluetooth driver is available for download from Vaio-Link (under pre-installed drivers).
I assume that you have turned Bluetooth on by double clicking the green LAN icon in the system tray and enabled Bluetooth?
To re-enable the Fn controls you may need to re-install some of the Sony utilities (again available from Vaio-Link - pre-installed utilities). Install Sony Utilities (installer 1), Sony Shared Library (Installer 2) and Vaio Event Service (Installer 5). Follow this with a re-boot and repeat a couple of times (if necessary) to get all working as it should.
Thanks for the help, solved my problem too.
Your'e welcome leehal, thanks for the feedback:smileyhappy:
