Very sorry for the long post
Just purchased the above laptop and having a few problems. Any advice would be of great help please.
Whenever I try to use the camera with MSN the system tells me it is already in use by another programme, so I have to restart the laptop and go straight onto MSN to get it to work. If I look under Device Manager I find two cameras under Imaging both identical VGP-VCC4. I have tried disabling one but this makes no difference.
Also while `playing around` I seem to have deleted all references to the inbuilt microphone. The system now tells me there is not one installed. Anyone any idea how to get it back please.
I have tried using `System Restore` everything goes through the motions but when it finishes it says it was unable to complete the operation and please try again, when the same thing happens. I have tried different dates also with no luck.
When I purchased the laptop the specs said the battery life was about 170 mins I am lucky if I get 60!!!
Lastly I have read on these forums that most people are trying to stop `My Club Vaio` running at start-up. Does anyone have a solution yet? I have tried the patch but it still runs at start up.
Thanks in advance for any advise.
Hi Philmike,
Welcome to Club Vaio..
The camera problem has been reported to Sony and we are currently awaiting a fix..
For My Club vaio you should be able to stop My Club Vaio.exe from starting if you go to start > All Programs > Accessories > System Tools > Scheduled Tasks..
Then dis enable the MCV entry..
Here is a guide on how Sony determines the Battery Life for Vaio's.
However in normal use it's probably about half that time..
Sony also has a guide on how to maximize the battery life of a VAIO notebook , which you may find of interest..
Many thanks for, with trying to push my luck...
Any idea how I can get my micophone back again and why system restore does not work.
Many many thanks for all your help.
