VGN-S1XP get's pretty hot on it's right side
Foxhound
Hi
I have the Vaio VGN-S1XP, with the following configuration: Pentium M 735 1,7 Ghz, 60 HDD, 1024MB ram and the Radeon 9700 graphics.
I noticed that the notebook gets very hot on the right side . With very hot I mean very hot, it is not very comfortable to work with on my lap.
Is this normal for the notebook to get this hot? I had a Vaio XG700 before this one and it never got as hot the S series.
Haven¿t read much about the issue and wanted to check out if it is maybe a fault in the notebook or if it is just normal?
Thanks in advance for any replies.
14 REPLIES 14
MatOakley
I have the same, and while it is seldom on my lap, it is on 12 hours a day and I havent noticed any hotspots such as you describe.
Mat
nick_pan
vaios like to get hot...
check out the thread in my sig for details..
Nick
TygerTyger
Hm........if your particular model has the cooling fan on the bottom of the base I'd watch you aren't covering it up with your leg or something wheil it's on your lap.
profile.country.en_GB.title
kee-lo_
If it's new get Sony to have a look.
jammold
Foxhound: Does the right side of your VAIO have a CDRW/DVD Drive? If it does and you use it a lot, then these drives will get warm, otherwise, as Kee-Lo said, if its new get Sony to have a look - the contact numbers can be found on the vaio-link website (LINK)
Foxhound
Thanks for the replies guys! No the DVD-Drive is on the left front side. Thank God I haven't had shutdown because of overheating like some others.
It's just that I expected the VAIO to be a lot more cooler then this. My sister has got a Fujitsu-Siemens with a Centrino 1.4 Ghz and it never gets as hot as my S1XP at the costs of 1000 Euros less.
Before the S series I had a Vaio XG700, the US-version of the X39 and I could work with it on my lap with no problems.
I just wanted to know if there are other S serie users out there with prior experience and get some info before addressing Sony about this.
Foxhound
Uhm... I d/l a temperaturemonitor. I get a idle temp between 40 and 50. When I play 3D games like NDS: Underground I got a MAX Temp of 77! DO I need to get my S1XP checked while I still have Warrenty?
Plz.. some advice...:smileycry:
kee-lo_
77 is steep, yes I would take action.
danstijl
thought your model has 512mb so maybe did you upgrade it to 1024mb? and maybe that's why, just a suggestion...
