Charging issue on Z4 tablet
Ilirg
Hi
Wondering if anywone else have the same issue as me. I really love this tablet but the charging time is terrible. 10% per hour with the tablet switched off. This is bugging me so much. I tried with my charger from samsung wich has a bit stronger output but same thing there. If i use The tablet while charging it will still not keep up even if I decrease brightness to 50%. Is this normal? I switched from ipad 2 air to z4
Slightly_frowning_Face
18 REPLIES 18
Ilirg
Allright guys Im finally starting to realize that what I read at other forums is starting to actually be true. Today I got from 74% till 100 in 45minutes. With the stock charger. And the tablet on. I guess its true that it takes 4-5 days for the battery to start working properly. I will let it discharge to zero then time it if I can to see the difference. To be cotinued....
Mjbecker
Hi
I ve a tablet z4 LTE and want to use a RAVPower® 10400mAh Externer Akku Pack Zusatzakku Power Bank USB Ladegerät für Smartphones und Tablet...
What do you think?
Many thanks for an advice
Manfred, Germany
drlmiles1
Contributor
I don't think there should be any problem. From experience using a similar charger with my old Z tablet, you should use the 2.1A socket, and the tablet will take a LOT of the charge - you will probaly get a maximum of two charges from the external battery, if that.
(Typed with the BKB50 keyboard, which I finally got to work!)
Laserdance
First Sorry for my Bad English.
For me here ist a Bug,
When Play a Game XCom: Enemy Within and plug the Standard Sony Charger the Accu decrased slowly.
The Sony Charger have not enough Power?
 The Sony Contact Formular not work. Send Button not clickable?
WuDu
My Z4 shows erratic charging behavior,  battery shows sign of charging but the orange light goes off and change stops at 50 or 60%. Restart sometimes turns charging on for a short time but percentage is not growing.  Battery app shows strange jumps in Voltage and temperature.
I have used different cables and chargers but it does not help. After about 3 weeks the battery should be formed,  although I have not discharged it completely,  just tried to charge it overnight,  from 30-40%.
Very annoying.
Asik
I have other charging issue. After latest android update tablet can be charged from wall only. Any attempt from PC or power bank is rejected.
Do you have similar experience ?
Lord_viridis
I'll test this when home.
Koey
Im using the sony quickcharge uch10 which utilize the qualcom chipset that z4 hv. its great. will be fullcharge in about 2 hours with charging rate of 1.8amp(reported by ampere application). the newer quickcharge uch12 will be faster i belive with a rate of 1.9amp. ive test with normal samsung charger with rated of 2.0, the actuall rate is only 1.5amp. btw with the note 5 charger that support qualcom quickcharge, the charging rate is 2.6amp! its the same speed i get from aukey quickcharge powerbank.
Triton1948
My Z4 Tablet charges very slowly despite having a new charger and cable and being checked by a computer technician.
It also loses charge even when charger cable connected
