The FM Radio doesn't seem to be working, doesn't matter if I try to play it via the headset or speakers. All it does is turn on the microphone on the headset and plays that. The only workaround I've found is pressing the TrackID button. I've tried clearing data for the FM Radio app, but still not working. Any suggestions?
I don't think I restricted any apps. I did not get any errors.
So I disable Ok Google and it's worked like a charm. Seems like Ok Google was interfering with the FM Radio app, which would explain why it turned on the microphone.
Did both, still not working.
Have you restricted any app? Do you get an error? Disable Ok Google and report back
Thank you It's working
