Translation via Google Translate:
I do not get voice notification after the battery is full after charging
saya tidak mendapat notifikasi suara setelah baterai penuh setelah mengisi daya
Hi @ratatouille, welcome to our forum!
As @Quester mentioned, your question has been translated to English as this is an International forum.
You might experience that there is no sound notification when the battery is fully charged after updating to Android 8.0 (Oreo). This is a known behaviour that will be corrected in a later software release.
The feature has not been removed and it will return in a coming software update!
I hope that helps and I'm sorry for the inconvenience!
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum. I see you issue the post header in English so please do the same with the post body.
The feature you mentioned was removed in Android 8.
