Battert Drain issue on 4.3? Xperia M C1905
NicklasCRJ23
have somebody feel some battery drain issue on 4.3? i've update to 4.3 and battery life is very short if i normal using it ? may be it's only 4 - 5 hours if i using it and it will be extended only when i sleep this because stamina mode? this is battery drain issue or my battery is broken?
5 REPLIES 5
Phy
Legend
Legend
Nope, I don't think your battery is broken. I think that is normal. If you just updated your software I do believe the phone battery will drain faster in the beginning. Take a look at the link below
/t5/FAQ/Battery-time-and-enhancement-features/m-p/347874#U347874
NicklasCRJ23
 am i must disable all feature? Expressionless_Face
Phy
Legend
Legend
Try re-installing the latest update with Sony PC Companion. And see if that helps.
http://support.sonymobile.com/us/tools/pc-companion/
NicklasCRJ23
i've been try that almost 5 times since my xperia m has problem with date and time but still not work too, my battery still drain until know Slightly_frowning_Face
Phy
Legend
Legend
You should get in contact with Sony Xperia Support.
http://www.sonymobile.com/global-en/support/contact-us/
