Battery Issue Kitkat 4.4.4
Nano1986
Hello community , I am writing to check the following problem. Recently, about 3 weeks the battery from my phone started acting weird , marking the apparently normal battery but actually was not. First it started with a wakelock of Fastdormancy that produced that could not enter sleep mode. After this I tried reflashing the rom again to see if this was solved and seemed so, but it was not for long, because the battery started dialing a wrong level . This is for example having 80 % and using the screen without stopping between 30 and 40 minutes and was discharged and so follow this matter without an understandable consumption of the battery , all things normal, but it's not what you really have to make . Subsequently i root my cell to see if an app Battery Calibration could fix this problem but it remains a battery which is not consistent with what at first showed me it was 1 day hours aproximadamante . I hope you understand the problem , I used the google translator because it would take too long to write the problem. I have last kitkat version of my carrier company. From the last battery charge it marked 3 days remaining.Screenshot_2014-10-14-16-36-53.png
11 REPLIES 11
Uliwooly
Nano1986
Thanks, i tried the solution on that thread a week ago but it' didn't helped.
Uliwooly
Just wondering, have you unlocked the bootloader?
Nano1986
Not even tried to do it
Uliwooly
If you already repaired your phone with PCC
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
and that didn't worked then you should contact Sony directly
Uliwooly
If you want to contact your local Xperia Care
http://www.sonymobile.com/global-en/support/contact-us/
Nano1986
Yes i tried that and it didn't work too
Uliwooly
Then you should contact your local Xperia Care
Nano1986
Yes i would try this. thanks!
