Battery Life Problems
GilGily
Hello,
I recently purchased the xperia sp and I'm having troubles with my battery life
My battery drains really fast compared to other SPs.
Here are the battery statistics:
http://tinyurl.com/kxdtswa
http://tinyurl.com/l9qmom8
http://tinyurl.com/jwny27g
I'm not using it in an intensive way...
Are this "specs" normal or not at all?
Thanks for the help Slightly_smiling_Face
9 REPLIES 9
Uliwooly
Stay away from this apps
taskillers
taskmanager
battery apps
ram apps
booster apps
this apps will drain your battery faster, as you can see on the graph your wifi was on all the time and it was awake quite often, this is caused by certain apps, if you are not using wifi then turn it off, as there are myriad apps that will upload/download/sync quite often, on a side note 18hours and 22% left its a good battery life
GilGily
Okok Winking_Face
The 18hrs are good even if there is 6h oh night time in it?
I have location based wi-fi and sometimes stamina mode.
Ashroft98
Enthusiast
If you have problems with Stamina Mode Standby Hours(example:no difference in Standby hours even when switch ON Stamina Mode),try clearing data for Stamina Mode.
Go to Settings->Apps->Swipe to the most right "All Apps" Section->Search for Eco Mode Controller and press "Clear Data".That should solve it.
PPS
My battery is poor than what the previous user has provided. It doesnt last even 12 hours on STAMINA mode too. My usage is moderate with access to Whats app once in an half an hour. No games loaded yet.
Ashroft98
Enthusiast
Do you use WiFi or mobile data?Then check your brightness and also , check whether auto-sync is ON or OFF...
chriss80
Hi
I am having same big problems.
Brand new phone and it drains.
Any solutions?
Thanks
Ashroft98
Enthusiast
Follow all the tips up there and avoid from using too much online apps all at the same time.Use Stamina Mode.
GilGily
Will it be the MacAfee - Pre-installed on my phone - draining my battery?
Ashroft98
Enthusiast
Yes,maybe.Since its a third party app,it might be using most of your power.On top of that,its an antivirus app.So it will absolutely use more power in order to regularly scan you system.
