hello guys, i brought a new xperia z2. i have a doubt when the flash is set to auto flash mode. the camera uses the flash most of the times when pictures are taken. i think the light is enough for the auto flash not to be turned on. any one faced this problem ? is it really a problem with my handset ?
My suggestion, turn off the flash and only use it when you really need it. Also its wise to use manual mode so you can select the SCN
yeah right now i am suing with flash off . but i would like to know if its only with my handset then i can get a replacement. if its with software then i can wiat until they fix.
but thanks for the reply.
This should give you an idea on how auto flash work
