One day suddenly my sony xperia z1 compact stopped charging or charging too slowly.I searched google for help and i found and followed this instruction:-
2014-09-23 02:52 PM
Just as suggested above you should try to charge the phone using another charger. Also try to press and hold the power button and volume up at the same time until the device vibrates.
After doing this step my phone started to charge normally again except when i plug in my charger now stamina mode stops working.it did not happen before.I tried factory reset but no change.Why does stamina mode stops when i charge my phone after doing the above step?Did it changed any settings?
Thanks for any help......
