I have a detailed contacts list in Outlook, and saved in documents as a csv file. It's taken years to collate and I would like to copy it into my phone, including addresses and notes about birthdays etc. Is there a way to do this? Ideally, it would be magic to delete contacts from the phone memory and the sim and transfer them all fresh. Otherwise I'm going to have a lot of typing to do!
I would suggest you use googlemail to copy your .csv into and then sync your phone with the google account and your contacts will load on to your phone.
There is no space on the phone for birthday, but again in google you can use their calendar and sync that with the phone. You have to add a special calendar
http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=37098
Have a look in the More section if it isn't open when you click in the link.
I use an app called Jorte on the large X10 which I think was a market freebie and its much nicer in my opinion than the stock one and you can sync that with google calendar, you could give it a go on the mini to see if it works for you.
Hope some of the above helps, but if you need to ask anything else please fire away!
