Memory Card Won't read
Not applicable
Hi!
I just bought the Sony Ericsson Xperia x10 Mini Pro. I have a problem with the memory stick. It says it's connected and everything, but it also says it's empty. Main point being; i can't get the memory stick to work.
I use  the default memory stick (2GB), the one that came with the phone.
I need help as soon as possible.
Thank you
7 REPLIES 7
Jeff
Enthusiast
You've put files on the memory card but can't see them? Are you unable to save pictures? What doesn't work exactly?
Let me know. I'm a bit unclear as to what is happening.
Not applicable
Thank you for replying so soon:smileyhappy:
I've inserted the memory stick and it reads, but it says the memory stick is empty and there's a memory stick with a red cross in the top left corner of the screen. When I try to take pictures it says I have to insert a memory stick. It's like the memory stick is broken or something. I've tried two different memory sticks and everything, but the same happends with both of them Thinking_Face
Jeff
Enthusiast
If you've tried two memory sticks that both don't work, you have two potential problems:
1) Software: Since the phone recognizes SOMETHING is plugged, its possibly a software issue. Run PC Companion Phone Repair option (http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pccompanion/xperiax10minipro?cc=g...) and test it again.
2) Hardware: You should either return to your dealer, or contact your local Sony Ericsson office to check on warranty/exchange/repair options (http://www.sonyericsson.com/cws/corporate/common/contact/phonelist)
Not applicable
Thank you, thank you Winking_Face
Not applicable
I need the memory card connected to connect the phone to my computer Neutral_Face The store i bought it from has the worst customer support ever. They won't even look at my phone Slightly_frowning_Face
Er_Kannan
Contributor
Did you try some other memory card or use a crad reader to make sure that the problem is not with the memory card. Try to remove and reinsert teh memory card and try again. Keep us informed. You will be helped.
Not applicable
HI
I appeared to be having the same problem, so removed the card and pushed it in and out a couple of times then refitted it.  It seems to be working now.
