When I put memory stick in the phone slot the phone asks me if i want to format memory card and what the content of memory card will be lost, I press "yes", then it asks for access code which is 0000, then it comes back with "formatting failed" and the phone cant find any memory stick ...
Any ideas how to fix this problem?
Btw sorry for my bad english.
Can't say for sure where the problem lies, but you can format the memory card on the PC with a USB card reader.On the other hand, it could be a phone problem, in which case you could try updating/re-installing the software via PC.
Which phone have you got?
K800i and yes , the memory card format was already done on my PC, but it didnt help, the phone cant recognize the memory stick(
Then run a software update/re-installation via PC on your phone and failing that, try a different memory card and/or try phone repair via PC suite or a master reset.
