model no. - LT22i
android ver.- 4.1.2
build no.- 6.2.A.1.100
I recently updated my xperia p handset using pc companion. Subsequently i am facing two main problems :-
1> While making a call, when i choose a contact from the address book then the screen which reads "calling" is displayed after a delay of few second. Its a major problem bcz i cant make out whether d call is connected or not. I do hear the ring but i cant c d calling screen for a few sec. For dat duration of few sec i see d contact list from where i chose d contact and not the ( eg John calling) screen.
2> Second problem is with the watsapp app. Sometimes when i start d app to type a msg b4 update i am unabe to type anything. But yes i can insert smileys. This never used to happen b4 update.
Please help me to fix these problems.
hi, you might want to re-install the software, just make sure you backup phone data.
Try disabling stamina mode,see if the lag is reduced.Also,restart your phone 1-2 days.
back up your contacts, messages, then your fav apps // now go to settings, backup and restore then click factory data reset .. doing factory reset after an update is a must ..
