Problem with charging/acc port
Not applicable
Every SE phone I have had for the last 7 years has this problem. After a few months the accessories and charger do not make proper contact with the port so I can not charge the phone correctly. I need to put a rubber band of increasing pressures until that finally fails to work and I need to get a new phone.
Please is there a way to fix this? (yes I know SE switching to micro USB would fix this but we all know they will never do that)
1 REPLY 1
Aimee
Enthusiast
So we may troubleshoot this further with you, I would recommend e-mailing our Technical support team on the e-mail address below:
[email protected]
We will then ensure a member of the correct department contacts you further with some suggestions to resolve the issues you are experiencing.
With regards to the charging ports, I can confirm that some of our most recent handsets use either the Micro USB or Mini USB connections. For information on these products, I would suggest visiting the link below. I hope this helps you.
http://bit.ly/Zl4Wx
