Problem with MMS on X10 mini
Not applicable
Hi, I need help with mms. I can't find in APN settings of MMS settings of wap, so I can't use MMS, because i must choose in APN MMS version of wap 2, but i can't find this option, help me please.
1 REPLY 1
Aimee
Enthusiast
I have noticed that you have had no responses to your post and I'm here to help.
You would need either the full settings sent to your handset to activate the MMS function or the MMS set up information sent to you. This information can be provided by your network operator. Once you have this information you would need to do the following:
Main Menu > Settings > Wireless Control > Mobile Networks > Access Point Names > Action key (Silver button with four squares above it) > New APN
I hope this helps.
