unfortunately stopped problem
ASIF902112
my phone (xperia neo v, mt11i, 4.0.4) is not working well. it gives the notification that com.process.acore has stopped, com.process.media has stopped.,,and list of unfortunately ......has stopped.so how i can fix this problem..i also factory reset bt problem still there...
5 REPLIES 5
Er_Kannan
Contributor
Try a factory reset. Make sure that you backup any important data before performing factory reset.
arturiu
FYI, this is an Xperia V thread, not Neo.
Anyway...
If you already tried a factory reset, then you may need to recover the firmware to a well known state.
But first do a backup (repair will erase your phone)!!
Here's some guidance on that:
http://talk.sonymobile.com/t5/Xperia-Ion/Alternatives-on-How-to-backup-Xperias/td-p/161240
Then, repair your phone with:
Update Service (SUS)
PC Companion (PCC)
Bridge (for Mac)
Also, be sure to jump to the Neo V  thread.
ASIF902112
I hv done that bt problem still there....
ASIF902112
ASIF902112
if I will update my android version to 4.1.B.587. then should it better 4 me or not....
