walkman crash yet again, consistent problem:(
mits999
So i got my xperia sp's software formatted and installed again. Did not have any crashing problems of walkman while browsing, but 2nd day day it crashed once and on subsequent days it crashed yet again. I guess it's a cache problem. Although I did empty next browser's cache, but the problem persists.Free ram is around 250 mb.Can Anyone plz gimme a solution to this problem? M tired of it Slightly_frowning_Face Slightly_frowning_Face
Tags (1)
7 REPLIES 7
Sam
Legend
Legend
Just to clarify, is the Walkman application closing only when you are browsing using the default browser? This is very odd as the two applications are not tied together in any way. Does the application also crash when you are using it directly?
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
mits999
No. The problem persists with other browser also called next browser. And the walkman never crashes while using it directly or while using any other app.it crashes particularly while using 2-3 tabs at a time or while browsing heavy pages.it happens every 5-10 minutes, the Track is playing, automatically it will stop and then i have to play it again.
Sam
Legend
Legend
Is the music that you're playing at the time on the SD card or Flash Memory?
mits999
The music is stored On the sd card and the free internal memory is 3 gb.
Sam
Legend
Legend
Just to narrow down the cause of the problem, can you put some music on the internal memory and see if the same problem happens when you try to play that content?
mits999
Just tried it. Even worse. Walkman crashed 3 times within 2 minutes while playing a Track that's stored on my internal memory.
Sam
Legend
Legend
Ok, in this case given the problem and what you have tried to resolve this I can only advise you to return the phone so that it may be assessed by an authorised repair agent sorry.
