When I'm using Headset and playing Walkman, sometimes the song played gets stopped. I have to remove and reconnect the Headset and then Walkman goes on fine. This thing happens most times.
Another Problem is, when I'm in Call, the Walkman gets turned off for the Call time. But after my call over, Walkman doesn't start automatically. It has to be started manually. Please help me regarding these two Problems.
1st Problem is solved. But 2nd Problem is still there. I meant that Walkman gets off after a call. It doesn't start automatically if it was on before call.
