i am facing problem with notification sound. It works fine while any facebook notification comes but when some message comes, it doesn't work. Even when i get a message showing last call charges or any watsapp message phone just vibrates but there is no notification sound. However my phone plays notification sound while receiving facebook notification.
Hey Guys,
I am also one of the victim of this ics update ... no notification sound whatsoever, after restart; phone starts sounding again, but only for 2 or 3 Hrs. I have visited sony service center, they did what we are doing after reading various comments here n there. And well, after lot of frustration, I found a thing called Safe Mode, you can start your phone in safe mode by following a procedure. You can simply google for it and will get first hit. Google for 'Safe mode start xperia phones' and btw I got Xperia P. Safe mode basically means .. it deactivate anything from 3rd party which came with this update ... and touchwood my phone is ringing since that safe mode thing.. i will find out which application is culprit .. if my phone keeps doing what it should do when receive email. Please try to do the same and tell me does it help !! You can go back to normal mode after restarting again. Link for you
http://forum.xda-developers.com/showthread.php?t=1863375
Best of luck.
^ Agreed
maybe there are 3rd party apps that's causing this problem. good luck to you.
Hi
I Have this Problem
i think is a bug in this version of android in Xperia Sony Mobile
Using Astro File Manger there is Notification folder in that Delete all the Notification tone . If u see the Notification tone again then delete that . I hope these may help Xperia P users.
I am using Xperia P. I upgraded to 6.1.1.B.1.54. Since then i am having the notification problems of incoming messages from the sim carrier. pleae help...
Hi
i have this problem and i solve it with this way :
Using Astro File Manger Or Any File Manager there is Notification folder in that Delete all the Notification tone . If u see the Notification tone again then delete that . I hope these may help Xperia P users.
it's Worked for me ...
i Don't Know Notification folder worked for what app ?!
I was also facing the notification issue, all of a sudden the notification stop working than i have to restart the phone and the notification would work for another 4-5 hours and again the same problem than after reading so many complain i came to know that most of the xperia p users are facing the same issue , and even the service center guys was unable to resolve the problem , so i tried some steps and it worked for me , i stopped update center and update service..i think in every 3-4 phone is sechdule to search for update through internet and once this process start notification stop working and after i stopped the update center and update service my phone notification is working perfectly from last 8 days... i came to this conclusion because when the notification sound was working i had checked the services that was running and once the notification stopped there was this two extra services that was running so i decided to stop the services and check and its work for me .. i hope it will work for other xperia P users as well i had also disable some time line services as well.
Let me know if it works for others as well
No i change the notification tone, but the same problem continues.............
But i didnt connect to the internet, normally it stops ringing after i talk a call, b'coz call cost notification comes msg notification stoped after that, so sony pls fix this problem soon as posible, this problem continues for more than 3 months, but sony didnt make any action for this, pls give us a good reply
finally culprit is found ........
the application vch is creating problem is "Google Talk"
as v cant uninstall it, I disabled it by going to stetting, applications , all app dr ul find talk . disable it n restart ur phone
i had done it and did nt face dis problem since 2 days
so this may help all.
