Hello
I own a LT26i,running 6.2.B.1.96 and recently had a friend install cwm recovery on it, it was alright until I got an ota update tried to install it but half way through it cut off so I asked him to remove cwm recovery, he did but he didn't do it properly, my phone doesn't connect to my computer now or connect to WiFi, when I put it on charge and its off it will turn on and then charge, adb doesn't recognize it and when I plug it in on recovery mode the computer starts searching for a 'S1 boot' driver, so it turns out he deleted the following files:
/system/bin/recovery.tar
/system/bin/chargemon
/system/bin/charger
/system/xbin/sh
what should I do, any help is appreciated,
thanks a lot
Have you tried holding volume up and power until you feel 3 vibrations then regarding connection to your Pc are you holding volume down then connecting your USB cable - You may also want to consider manually Flashing see here for details if you are unsure how - You may also want to consider Fastboot and using a command prompt try flashing the Kernel only as this may be your issue as CWM is a modified Kernel
