Battery drain
SOLVED
Hassoun907
Battery drain
Is it normal guys i really think that there is a big drain i am all time checking my battery what is the cause of my drain do you think
37 REPLIES 37
profile.country.US.title
Qatrium
@Hassoun907
You have a new phone, you play with it a lot. This is obvious from your screen on time, as alexdon stated it consumed about half of your battery life. Once you settle with your usage and setting phone preferences and go back to normal usage you'll notice a longer battery life. Also reduce screen brightness a bit if you want your screen to consume less power.
Uliwooly
@Quester
Those are great suggestions, also
Settings > display > Image enhancement > off
dandy63
Leader
@Hassoun907 Having read thru all the questions/replies i can assure you everything looks great & your phone seems to be working perfectly......as mentioned, stop worrying/checking your battery stats as this drains the battery!!! If thru normal use you get approx 2 days then it is fine.....the most i have had is approx 2 1/2 days of use. Obviously if you are a heavy user the the battery drains faster....no smartphone will ever sit unused & not lose battery, there are always things running in the background. Dont let the phone completely drain/switch off before charging....dont worry about overcharging either.......
All these points have been made already......but i think you just keep looking for assurance......go & enjoy your phone Slightly_smiling_Face
Enjoy my friend
profile.country.RO.title
_alexdon_
You have covered everything,now I will close the topic as there isn't need for further clarifications.
alexdon
Hassoun907
I read on some blogs that discharging my z3 battery completly have some benefits for longer life ???
what is the true is it bad or good
Phy
Legend
Legend
Hassoun907
Hiii my z3 I cannot afford a full charge because off my short free time at home i chargrged my phone to 85 before I go to sleep .i woke up in the morning with 5% lost with stamina mode and i complete my charge  and since I started this charging type i having 3hr30min screen Ot and18 hr of full usage with 50% left because i charge my phone between 30 to 50%
Samuel1
Hero
It shouldn't matter if you charge 30-80% or 10-100%, the battery can handle it either way.
