Sal 70-200 Lens Picture Quality
Beauchiefs8
Kestrel at Lodge Moor 23Jan2017Crop.JPGI am not getting definition and picture quality I expected from Sony SAL 70-200. Example attached taken 1/640   f5  100 iso  On Ilce 6000
16 REPLIES 16
Beauchiefs8
Thanks, I'll try that I thought the L setting was for best resolution.
regards   Ian
Beauchiefs8
I already had the setting on Large 24,  Fine,  Not sure what else to try other than faster speed?
Beauchiefs8
Another example uncropped taken 1/800 F7.1 iSO 800 L 6000x4000 Fine, I think it is a focus problemWaxwing 2 uncropped.JPG
MHFoto
Enthusiast
Why f/7??? Please use the 200mm Lens with f/4.
And you are still to far away from the bird. It is not a focus problem.
Is there a Zoo in your city? Go to the Zoo and test the Lens on objects they are closer to you. It is not possible to make a picture with 200mm focal lenght and 100m distance, crop over 90% of the image and get an sharp result.
You should go closer as possible.
MHFoto
Enthusiast
Let me show you something.
ILCE A7R cropmode 1,6 on (near the same image section like with the a6000)
ISO 400
F/4
Shutter speed: 1/1250 sec
Focal length: 200mm
Lens: Sony FE 70-200mm F/4
Tripod: no tripod, freehand
Flash: no flash
Distance to the bird: 5 meter
Beauchiefs8
Thanks, my expectations for the lens are too high, I have had it for nearly 2 years and get good results from closer. I should perhaps have bought a different camera but have spent a lot of money on this system and will have to make do unless there are any longer lenses I could fit on the a6000.
Best regards   Ian
MHFoto
Enthusiast
It is posible to conect othe rlenses to the sony system. There is an adapter from commlite E-Mount to EF for 50$.
With the adapte rit is possible to use the Tamron or Sigma 150-600mm on your cam. But a tripod an a gimble are absolutely neccesary. The lenses are big guys and they are heavy. As i know there are no other lenses from Sony with higher focal length.
Tamron on a6000
https://www.youtube.com/watch?v=xcCUOg9-7bg
Sigma 150-600 on a6000
https://www.youtube.com/watch?v=kxZnbPXmZYk
Commlite E-Mount EF Adapter
https://www.youtube.com/watch?v=WRgsSepyo4g
