Yongnuo 685 flash freezes after one flash with Yn622C mounted on Sony A7Rii
Pro-f-sor
New
Got a strange one-
New Youngnuo 685Flash with built in reciever which works with Yongnuo YN622C-TX flash controller.
All works well off camera when tersting - ie triggers the flash consistantly. As soon as i mount it on the Sony hotshoe, and take a image, it will fire the flash as expected but then the flash link LED remains on in a constant red state and effectively freezes the flash (NOT CAMERA).
I have to power down the flash and restart and then take another picture and the same cycle occurs.
Anyone have this issue and how to overcome it?
2 REPLIES 2
DanoDAS
New
Hy!
The same problem I have with Sony Alpha 3000 and Yongnuo 560 4. When I slide the flash in, it fires and the red led stay lit and I can't acces anything on the flash display. When I slide out the flash, it trigers and unfreeze.
Do you hava a solution for the problem, please!!!
Pro-f-sor
New
I still do not have a answer - still hoping someone will find a solution :thinking:
