Sony Bravia KDL-42W653 and Humax Youview
SOLVED
havisham
Hello
In the past week, my Humax DTR-T1010 Youview box has started displying in Wide-Zoom mode instead of Full 16:9.
I have all the TV's inputs set to Full as a common screen setting, but the Humax (on HDMI 1) is always in Wide-Zoom.
This has only just started to happen in the last week, after the Bravia updated itself.
I can't manage to find the screen settings just for the HDMI input - can anyone point me in the right direction please? It's driving me mad.
Steve
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there
Two ways to do this (easiest way is):
  1. Ensure that the YouView box is on and is displayed on the screen (ie on the right HDMI input for YouView)
  2. Press the [Sync Menu] button on the remote control
  3. Scroll down to "TV control with the TV remote" and press [OK] on the remote
  4. Use the TV's remote control and press the [HOME] button
  5. Goto Settings > Display > Screen  and then ensure that the details are correct.  If you want all the same settings accross all devices, set Target Inputs to Common and that should be it (assuming that the Common is correct)
  6. Once done, press the [Return] button on the remote control repeatedly until all menus are gone
  7. Press the [Sync Menu] button again.
  8. Scroll down to [Device control by TV remote] to disable the TV control from step 3 above.
Hopefully that should resolve it.  I probably should have created these instructions before hand  :wink:
Cheers
7 REPLIES 7
Anonymous
Not applicable
Hi there
When viewing the YouView on HDMI try changing the Screen Settings using the following instructions:
http://pdf.crse.com/manuals/13LW600114/EN/c_picscrn_size.html
You could try setting the Target Inputs to "Common" which is set to all devices/tv (hence all the same settings)
Hope this assists.
Cheers
havisham
Thanks for the suggestion Quinnicus - when I press the Home button whilst watching the Youview/HDMI 1, nothing happens - I can't actually get to the home screen. Pressing the Options button doesn't do anything either. I've noticed that all of the external inputs are displaying as wide-zoom, so I guess I must have changed something.
I think the Target inputs were Common, but I may have switched away while I was trying to fix the problem - I'll have another go.
Thanks for your help.
Anonymous
Not applicable
Hi there
Cheers
havisham
Thanks again Quinnicus - I would never have found that by myself!
Steve
fogralea
Hi Quinnicus
I found your solution for the same problem that I have encountered and only had tv 3 weeks!
I have just followed your instuctions and it seems to have done the job!
Regards
fogralea
Thanks Quinnicus - I would never have found that by myself!
All sorted now but you would have thought it would have been easier to get to menu!
Fogralea
Anonymous
Not applicable
Hi guys,
Sorry for the delayed response, I am glad it works and you're welcome :slight_smile:
Cheers
