- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
battery questions
hi there guys
Can I remove the laptop battery while plugged on AC whithout shutting down?
Moreover do you know how should I store the battery.During the week I only need the battery once all the other days I run the laptop 24/7 so I don't want to wear the battery because it doesn't discharge regularly. Can I put the battery on the self of my library for example or in a drawer . Does it need a special place to be stored?
thanx
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Personally I would shut down before taking the battery out.
You need to keep the battery in a dry place where it's not too hot and not in direct sunlight.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanx for your response
Do you thing it is good to remove the battery considering how many times I use it?(Once a week aproximately) You know batteries are expensive so I don't wont my battery to be destroyed before it's time
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It's a good idea to condition your battery. Batteries develop a memory and as they get older it is possible to lose a certain amount of this memory . The battery will charge up to the point that it thinks is full up.
It's a good idea to run your battery right down before recharging. This keeps it conditioned.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
This is a common mistake people make these days, new batteries don't have a memory so they don't remember where they were upto so it causes less damage.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks
