Bought a FS215S a couple days ago after buying a FS215B for a friend, though it seems my (CPU) fan (??) is constantly running, which is quite annoying. My friends 215B only turns on once a while for only couple seconds. My CPU temp. is around 46'C .
Also when turning down the brightness I get that annoying buzz/noise.
I also have a dead pixel 😞 What's Sony's policy about these problems??
But has to be said, the screen rocks!
Hi yonggui, welcome to Club Vaio.
I have a FS215z and my fan seems to run constantly also, the temperature is also similar. I've been told by a couple of the guys here in the forum that this seems to be the norm for these Pentium-M processors and after reading the info at the Intel site this would indeed seem to be the case. However as you say it is a little annoying (& dissapointing).
I don¿t get the buzzing noise from the screen though I know one or two other forum users have mentioned it, but combined with the fact that you seem to have a dead pixel I would seriously consider returning it to the supplier.
It seems when starting the computer from 'cold' the temperature keeps around 36-37'C here, here the fan is not running yet.
Slowly it goes up to 40'C and then the fan hits in, no matter if the temperature is 40'C or 48'C (never had the chance to torture the CPU
), the fan keeps running at the same (slow) speed.
Now I'm just wondering, why not just cool the CPU down more and turn off the fan instead of keep it running around 46'C?
Also why does the FS215B NOT have this "problem"??
Not really sure why they did that, but it would have been better for the user if they did do that
Slowly it goes up to 40'C and then the fan hits in, no matter if the temperature is 40'C or 48'C (never had the chance to torture the CPU), the fan keeps running at the same (slow) speed.
And like you say; why does the FS215b not have this problem?Can I ask: what utility do you guys use to find out your temperatures?
Most fans can last a long time even with heavy use (5 years or so)
