HARD DRIVE REPLACEMENT NEEDED FOR VAIO S2XP
barrieeld
please help, i put my computer into hibernation the other day and when i turned it on i got the "Cannot find Operating System" error being displayed. As well as this i get "0200: Failure Fixed Disk" I cant believe it.
I really need somone to A:) tell me if i can resolve this matter and maybe save some of my data or B:) Tell me what hard drive i need to get to replace my 80GB one that has suprisingly just went on me.
Thanks in advance.
Barrie
8 REPLIES 8
rich912
Contributor
Hi Barrie and welcome to the forum.
I am sorry to say that a 0200: Failure Fixed Disk error message usually mean that the hard disk is beyond recovery but just occasionally it is a cable connection problem. If you feel confident enough you could open up you notebook and check the seating of the connector between motherboard and HDD.
If the HDD is dead then data recovery is still possible but you would need to contact a specialist company. I am afraid that this option is far from cheap and usually reserved for corporations that need the data more than their money!
Any standard notebook hard drive will fit your notebook – 100 x 70 x 9.5mm
Go n-éirí an bóthar leat
barrieeld
Hi there thanks for the response.
Is there any guides anyone can point me to for replacing my drive? I can confident with PC but never tried a notebook before.
So any 2.5" Notebook Drive will fit then i take it?
If somone can post instructions i would be most grateful.
Ragards
Barrie
khanate
Use google I found a guide (in german though ...) for my vgn a297. Be sure to buy a 7200 drive while youre at it!
barrieeld
Hi there can you reccomend any particular brand and will this be guaranteed to work in my S2XP
thanks
oldoscar
HI
am posting on lots of threads ..hdd crashed replaced with identical model(IBM TRAVELSTAR) started recovery...disk failure at 19% examined
problem with disk one ..raised area on disk...NOT a scratch..have little help from SONY..(they have even closed their 0845 No).Have had 3 Vaio's..but my next won't be
oscarsmazlen
Thalamus.
Champion
Hi oldoscar,
You can purchase a set of recovery disk's from Vaio-Link, you can contact them either by phone , fax or via E-Support...:smileyhappy:
oldoscar
HI
I have found that I can purchase a set of disks(I only want disk one)but the point here is the the disk supplied was not fit for purpose this was the first time it had been out of the case(how often does one need to do a full recovery with win xp I have found that winxp recovery works every time if you back up and make sensible restore points may be I'm lucky)
I have had three vaio's never a problem till now..I think the forum is great but the sony service leaves something to be desired ((IMHO))
LITEON back is superb...Topfield similar " Phillips service" is an oxymoron
I can get a legal winxp on ebay for £40 or get a hack for £10 but I gave that all up when I reached 65
Peace man(if you can remember the 60s you wern't there)
oldoscar
hI
sONY products are good but this first glitch has me wondering, I have been (my wife) off net for over a week with no replies If I have to purchase a set of disks when I don't think it's fair.so be it
But I will review my next upgrade which is to a 50 plasma ( was the sony tft) and probably buy a powerbook probably no better service but you have to protest the best way you can..
sad osc:smileysad: :slight_frown: :slight_frown: :slight_frown:
