Hi i have a A417m laptop and not so long ago it crashed so i gave it to a freind and he reinstalled windows, which wiped my hard drive hence i lost the recovery utility or so i thought but there is about 7gb on my hard drive that is hidden is it pssible that it is in this if so how can i access it please help.
Hi biggie944,
welcome tot the Forum
Press F10 repeatedly when you first turn on your computer this should allow you to access the recovery program
Thanks i tried that but nothing happened.
Take a look here, your system does not list the recovery utilitiy but it does list Preinstalled Drivers and Utilities
Hope this helps
Thanks do u know of anywhere i can download the recovery utility from or even buy some recovery discs from as apparently sony dont sell them.
This link may help you further
Link
Did you check ealier link for Preinstalled Drivers and Utilities
Tanks for the link i downloaded and installed these when windows was installed ,the reason why i am after the recovery software is to install the original sony platform and all its software.
The recovery ulitlity is not listed for your laptop however the application is listed for other models
Have a look in the Select Models drop down list, there is reference to the program their but as I said it is not listed for your model.
