Deel jouw ervaring!
Hiya Guys
Quick question,
I have a new VAIO Fit 15E and just went to put my Memory Stick Pro-HG Duo from my NEX-5 into the slot. I might be completely stupid, but with my previous VAIO the SD slot seems smaller making the Memory Stick fit perfectly. With this new VAIO, the slot seems too big and I don't want to push the Memory Stick in any further in case it gets stuck. Any ideas, as to whether I do need to push it in further or whether my new model isn't able to accept this smaller stick?
Cheers
Faith x
Opgelost! Ga naar oplossing.
Hi Faith.
Hmmmmm.... Most Vaios have two slots - one for SD and one for MS. It looks like Sony have dispensed with the MemoryStick slot on the new Vaio Fit. This is a bit odd as MemoryStick is a Sony format - perhaps they are bowing to commercial pressures as most people use SD Cards these days.
I think you can still use MemoryCard Duo Cards but you need a cheap adapter like this: -
Alternatively, you can use an external USB Card Reader or you can change to using SD Cards in your NEX-5.
Hope you are OK - See you soon?
Hi Faith.
Thank you so much hun, glad it's not just me being dumb
But isn't that such a load of crap, that I can't even slot my Sony Nex card into my Sony laptop!
I can of course just use my USB cable, but that means having to carry yet another cable around with me, so looks like I have to get the adaptor.
And yes, meet up soon, in fact I'll email you soon, as I'm just finalising a drive up north over the next couple of months - definitely over due for a lunch date
