tv out problems
madxbri
tv out problems
hi all now i have my pc up and running properly again i was wanting to link it to my tv i have the tv out and this conection
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=57189&item=6710799527&rd=1
but when i conect it to my tv with the yellow cable to the yellow socket on my tv and select that output on my tv i dont get any signal to it am i doing it right or do i need a diffrent cable to conect to my tv the tv video output cable is the one i got when i bought my pc do i need to set up the pc to use this output
thanks
Brian
ps does it need to be a yallow cable or will a red or white one do the same if conected to the lead i got with my pc
16 REPLIES 16
Snipes
i know it sounds daft but have you tried switching you tv to the AV channel?
madxbri
yes done that 🙂 and maked sure it was with my camcorder so not that how do you set the TV as the primary display?
profile.country.en_GB.title
robpaxton
You should only need to connect the yellow video-out on the PC to the video-in socket on the TV if you don't need sound through the TV. The instructions on how to activate the video output should be in the manual.
What model is your PC? The instructions for activating the video output vary from model to model and some PCs only have a video input (Like the PCV-V1).
madxbri
Hi the model is PCV-RX402
i tryd to download a manual thinking it would be clear to do but this site dosent list a manual for my pc i know it used to have one not to sure how to set it up i was raking on my pc and found things to set up on my graphics card to do with output but a bit scared if i set it wrong i will loss the screen then how would i get a pic to set it up again ?????
thanks
kee-lo_
Try this Bri.
madxbri
i take it that is the link for the user manual for my pc i have been waiting for 10 mins now for it to open 😞 i still have dial up for a couple of days till my broadband is set up i will waite and try again when it is set up it seams to be taking ages to download
thanks again Kee_Loo
do you ever sleep you are on as much if not more than me keep up the good work m8 thanks i just hope the manual if that is what it is on the link will explain things to me as it is doing my head in now lol i dont even know what i will use it for on the tv yet just thought it would be a nice touch seaing as i should be able to use it might come in handy while i have my sony camcorder linked to my pc or things like that of dvd's ect (have a dvd player on the tv already ) i am sure i will find a use for it when set up 🙂
kee-lo_
ido you ever sleep you are on as much if not more than me keep up the good work m8 thanks i just hope the manual if that is what it is on the link will explain things to me as it is doing my head in now lo
Yes it's the manual.
I sleep quite well at the moment thanks :slight_smile:
